aviator said:Ed and Sandra=
Where are you in North Carolina? We have a place in Brevard (close to Asheville).
I've always wanted to drive the XLR on the Blue Ridge Parkway, but I just can't make mayself drive it all the way from Texas.
aviator
Eyedoc said:Standby
Too bad you couldn't stop in DC. I would have hosted.
At least the Washington Monument is open again, Capitol is all torn up with visitors center construction, and you can't drive by the White House anymore, due to scurity.
hope you saw what you needed to see.
I've done the drive - just not in the XLR. I thought yours was bent.standby said:Aviator
Well I did it for you on the way to NYC..............Blue Ridge Parkway to Luray Caversn then on into DC to show my daughter all our government buildings on the way to Atlantic City...........We had no time to stop in DC
Ed and Sandra said:Salisbury, NC
aviator said:I've done the drive - just not in the XLR. I thought yours was bent.
Did you drive it all the way to NYC?
On teh 06 XLR the NAV/XM antennas are in BOTH ouside mirrors. They will pick up the strongest signal of the two.Robin said:The XM antenna is indeed in the outside rearview mirror. Talk to the XLR electronic's guy my dealer about installing 2006 mirror. That is no problem. The problem is the XM module is located on the under side of the trunk. To the right of the XM antenna. So you would have to either relocate the XM module or have a antenna cable made. Then figure out how to get it routed to the mirrors. The long antenna cable may also present a problem. Cable loss could be enough to have the XM radio not work at all. Moving the XM module would be a night mare.
Sorry about the above miss info. Robin
The XM module is not the one referred to above. That is the TOP CONTROL MODULE. The XM module's location is right behind the LED's for the parking assist. IF in the 2006 XLR the module has not been moved. It should be possable to buy the Antenna cable's and mirror's and install them on your 04/05 XLR. The service manual for the 2004 XLR explains how to replace the XM antenna cable's. So it stands to reason that the service manual for the 2006 XLR would detail the same thing. But I will bet that the Radio Head has been re-engineered to incorperate the XM module. Robin
I contacted the dealer and they ordered the wart for me, but I had second thoughts so I went to best buy today and purchased the mini xm antenna $40, I found out that I needed the splitter to convert the newer style "one lead" antenna to the older two lead type. Neither Best Buy or Circuit City carried the splitter, I found a place on the web that carries the splitter but didn't want to wait, I found a local auto audio shop that had one in stock, $30. Went into my trunk and found the leads plugged in where the wart would be connected right above the back of the rear storage unit, unplugged the 2 white prewired coax leads and connected the splitter leads then the antenna which came connected to 23' of coax. Ran the very thin coax wire through the bottom back of the passenger seat, tucked it under the passenger kick plate and up to the windshield. Very simple install, and the mini XM antenna was magnetic so it sticks to the center vent grill, works great everywhere except inside my garage!I am wondering if anyone has installed their XM without the factory antennae being drilled through the trunk, but rather in some other portable yet secure fashion? undefined
I have been considering doing the same thing. In searching the Vette sites to see what they did, many mentioned putting the antenna in the rear tailight housing and inside the rear of the vehicle. They claim fiberglass is invisible to the satellite signal. I was considering mounting the aftermarket antenna between the trunk lid and the trunk trim panel and see how it works.I contacted the dealer and they ordered the wart for me, but I had second thoughts so I went to best buy today and purchased the mini xm antenna $40, I found out that I needed the splitter to convert the newer style "one lead" antenna to the older two lead type. Neither Best Buy or Circuit City carried the splitter, I found a place on the web that carries the splitter but didn't want to wait, I found a local auto audio shop that had one in stock, $30. Went into my trunk and found the leads plugged in where the wart would be connected right above the back of the rear storage unit, unplugged the 2 white prewired coax leads and connected the splitter leads then the antenna which came connected to 23' of coax. Ran the very thin coax wire through the bottom back of the passenger seat, tucked it under the passenger kick plate and up to the windshield. Very simple install, and the mini XM antenna was magnetic so it sticks to the center vent grill, works great everywhere except inside my garage!
XM antenna part: http://www.crutchfield.com/S-AUz1IYMc804/cgi-bin/ProdView.asp?search=xm+antenna&i=209XMICRO2
XM splitter part: http://www.crutchfield.com/S-AUz1IYMc804/cgi-bin/ProdView.asp?search=xm+splitter&i=003XM1DAS
The dash mounted antenna is unnoticable and works well, I may try to install a second antenna in my trunk near the tail when I have a chance just to see if the signal will work in my garage, and to see if I can connect two in parallel.I have been considering doing the same thing. In searching the Vette sites to see what they did, many mentioned putting the antenna in the rear tailight housing and inside the rear of the vehicle. They claim fiberglass is invisible to the satellite signal. I was considering mounting the aftermarket antenna between the trunk lid and the trunk trim panel and see how it works.
Uintah
Let us know how it works. The XLR has been in the shop for 5 days now, so I haven't had a chance to do anything. I have a new stainless steel grill waiting to be installed before our trip to Idaho.The dash mounted antenna is unnoticable and works well, I may try to install a second antenna in my trunk near the tail when I have a chance just to see if the signal will work in my garage, and to see if I can connect two in parallel.
If interested in photos of my install go to this thread:
http://www.xlrforum.com/showthread.php?t=2568&page=2
