mcd-02 said:Hi,
Possible solution for front license plate issue.
Scott
mcd-02 said:Hi,
You are both probably correct about the air flow. That is the only down side I can see. I have new plates coming this month, and I might try to trim a little off of both sides to help.
I have not noticed any increase in temperature or poor performance yet.
For states that require front plates, I do believe that this is better than drilling holes and mounting a bracket, however, each of us has to make his/her own decision.
Still can't get enough of it.
Scott
Mr XLR said:Please take to heart all of what has been said here, since the upper main grille is just for show. The grille does not let ANY(0) air flow past the grille work, the only air is drawn into the engine from the lower grille area that you have now covered. Continued usage in this way will eventually cause damage to your engine.
www.Cadillac-XLR.com
www.CadillacXLR-V.com
Thank you
Allen
