May be a re-hash - but -- Does anyone know the actual "offset" values which are required as you move to larger wheels.
Stock XLR wheels are 8" width with a +51mm offset (as best I can learn). So as you go to wider wheels (8.5, 9, 9.5, 10) - what offset is needed? Obviously we need to balance the wheel-well width and "bias" relative to the wheel mounting flange to avoid things hitting. So does anyone know the required values (either my measurement - or experience)?
In addition to that - we obviously have limits on the tread cross section (i.e. width of the tread) - by research I am finding 9.7" for the front and 10.7" for the rear - does anyone have data confirming this too?
Does make you head spin a bit :crazy
Thanks
Thanks
