I removed mine, rear and sides. I think they're distractingEd and Sandra said:"XLR" emblems that don't snag cleaning cloths! Some idiot designed the current ones and how they're mounted. It's a miracle we haven't ripped one off considering the number of times we've caught terry cloths on them.
Best regards,
Ed and Sandra
This is correct.bumbleent said:I think you can scroll by putting your finger on the touch screen in the direction you wish to scroll.
Bumbleent
Tell me more! You mean if you push the raise the top button the trunk will close? What do you mean usually? I'm assuming you mean you have to have it in park?bumbleent said:I can usually close the trunk from the car by pressing the switch to raise the top.
Bumbleent
Upstateupstate said:Tell me more! You mean if you push the raise the top button the trunk will close? What do you mean usually? I'm assuming you mean you have to have it in park?arty
You are right I just did the same myself. Great info. Thanks!wreindol said:Upstate
I opened the trunk as normal from the rear, then got in the car and put it in accessory mode. Pushed the top up button, both side windows went down, the trunk closed, and then I got the "BEEP". Then I opened the trunk from the button on the dash, and went through the same routine, and everything worked the same. And by pushing the top up button again within 5 seconds after the "BEEP", both side windows went up.
alk3997 said:1) Rearview camera - display either in the Nav LCD or a Rearview mirror mounted LCD. I really miss that from my wife's Infiniti.
2) More use of the HUD - navigation information for a start
3) Better voice recognition (include "top down" assuming the voice recognition is accurate enough)
4) Bluetooth connectivity
5) Remote engine start
That's about it for me...
Andy
