1 - 2 of 2 Posts
Driver side front signal is out, back one still works.
Can I get a new bulb installed?
Also the cargo divider switch doesn’t hold for me to get the top up/down consistantly.
I have to get out and readjust the divider to get it to work?
Any suggestions?
Turn signl is a simple bulb. You do need to remove the heaflight. Its not hard to do. A dealer will charge you 150-200$ to replace it. A good bodyshop can do it for 1/2 that or you can do it yourself in 1/2 hour if the carget divider is not tight i usually put some heat shrink tape over the end of the shaft or you could wrap a little tape around it . if the switch is bad i have those
1 - 2 of 2 Posts
