Rear traction bar on the V.
The standard XLR already has the mounts for this bar.
Something to add on??
They just left off what they put on Corvettes; no rear sway bar for a more "Cadillac" sort of ride. You could bolt a Corvette sway bar right on if you want one.1_XLR said:Rear traction bar on the V.
yes, if you look under you car, you can see where it bolts up, same mounts as the C6.upstate said:I would like to consider this mod. Are you saying any rear sway bar for a C6 Corvette will bolt on? Will it be noticed enough to be worth it?
