Only problem
The only problem I have had is that the top retracted 95% of the way into the truvk then got stuck (this started after flawless operation for 4 months).
It was fixed with a microswitch replacement and nowback to normal.
I thought there was a problem with ignition switch taking you straight to "accessory" with only one touch. But, thanks to this forum,someone suggested that I look at the DIC. When this happens, I get a "Fob not found" message. So, I guess its because I keep the keys/fob in the left pocket and it is out of range sometimes when I turn the car off.
As with most high tech things, it is hard to "break" something by using it.
The top and the brake squeal seem to be the most consistent issues (but others have opined that the brakes are being addressed and that brakes and tops have been issues on other cars of this genre - and just take a bit of time to troubleshoot and fix at the global level).
