email#1
"I can see them using the SVS message on an early failure of a PCM/ECM code,
I don't understand this. My 2004 w/s manual is 100% transparently clear on the meaning of this message. It means 'non-emissions related problem' and it is raised by the ECM. This is not an 'early failure of the ECM' message (though that could be the root cause). Later on (in this thread) there is a note re legal wording, which is true as far as it goes. However, that misses the point that a non-emissions related fault (and there are many) must NOT light the MIL (SES) lamp. This means that the ECM has to use a different message. Sometimes it is a lamp (a red circle with a ! in it is used by some), the XLR uses the SVS message.
however they are required by ANSI to store freeze frame/fail record data when any code sets. I am not sure if we checked for ff/fr data even though the computer said no codes. we might try that next time you come by.
And then again, maybe not. If you have a power glitch in the ECM it could easily erase all the ff data too. Anyway, what will it prove if there is any?
On most cars the SVS message is reserved for body functions,
But not the 2004 XLR. It is 100% reserved for the ECM.
but like I said before engineers kind of do whatever they want since there are no laws around the use of this indicator/message. Please keep reminding me to do some research and feel free to stop by and I'll check the codes and freeze frames again.
See notes about legal meaning of SES lamp above. Also, it took me about 3 minutes to look up the meaning of the SVS message, and I am using a paper copy of the w/s manual.
email #2
There is a bulletin on some cars for certain issues to remove the connections, make sure they are clean and apply some dielectric grease. I have done it on a couple of cars but it really had no effect. It is possible to do it on your car but the location of the ECM makes it complicated.
It is in the right wheelhouse behind the front tire. You have to remove the shield to access the connections and even then it can be a pain because it is rather tight in there. How many times have you seen the message since you have been in last?
As you can read yourself, it's frustrating to know there are other error readings that could have, but weren't checked. There also is a bulletin describing the cleaning suggested here, but that wasn't found until I wrote him about it. By the way i read through the Service manual last night and when I finally got to page 899, it clearly stated that the SVS message is set by the ECM. sounds like the BCM is easily access and cleaned, but now I'm not sure that's the problems, but worth a try.
I'll keep you all posted. :skep
Well, the good news is your service tech is talking to you. The bad news seems to be a reluctance to get down and do what needs doing, which is the look very closely at the ECM and the power supply (which includes the grounds!!!) to the ECM. You are just going to have to do this, that is, get this done.
Now on another point, I was looking at my XLR and remembered this thread, so I thought I would check that all the fuses and relays in the underhood relay center are firm. You know what? Every single one of them snugged down when I pressed it, maybe only a 1/64 of an inch for some, but for one relay it had nearly fallen right out. So, easy job for you. Lift the cover on the fuse center and check all the fuses are firm. In 2004 fuse 11 is the ECM's constant power supply.
Look on the bright side, this problem with your XLR is going to be fixed!
