Guest
·Some tricks for the XLR
Press TC on the console and hold for 5 seconds and it takes off the TC & Stabilitrack system= much quicker off the line and you now have control of your XLR. Go pop a wheely, (not really). Still a little slow off the line? Change out the gears for a Vette 6 speed gear set up. You will also need the code from Cadillac for the computer, so the tranny and gears can talk the same language. It's about $2,500 but it would probably get your heart pumping.
A free fix from Caddy is available for the heat under the console from the exhaust, which during the summer gets really hot & just about boils water bottles in the cup holders. It's a space age heat reflector, which takes a day to put in.
When you buy this awsome machine, give yourself a good month, between work, play and romance to read all the books in the glove box. Plan on sitting in
your machine for hours at a time to play with all the gadgets that aren't just standing out there to be played with. This vehicle...OOOPS!....machine doesn't look intimidating on the inside unless you really know what's available to you under all that Carbon There are features that will bogle the mind.............and someone said this is not a luxury Roadster? He should be anshamed of himself.
