XLR Transmission Problems
  • No Transmission Problems Reported
    Votes: 18 81.8%
  • Transmission Serviced Due to Reported Problem
    Votes: 2 9.1%
  • Transmission Repair/Replacement
    Votes: 2 9.1%
21 - 31 of 31 Posts
I don't understand what being an arbitrator has to do with lemoning a vehicle that by all rights you should have been paid every dime you spent on that vehicle less the mileage.
You could have not come close to a deal such as this by dealing with a dealer.
I lemoned an 04 and when all was said and done, It cost me $5,000 more for an 06-V
Bobo
No I did not...Because I am a lemon law arbitrator and I would had to drive a long way to another arbitrator that didn't know me.
The dealer made a deal that would have been the same.
I drove my '05 XLR this weekend from Jacksonville to Orlando. I experience this around the 85 mph range. If I keep a non-constant single speed there does not seem to be an issue - however at intermittent times around 85 mph while I keep it steady it seems to 'slip' or 'bog'. When I get off the gas or back on the gas it goes away.
I am going into the shope tomorrow before a trip to Miami on Wednesday.
Update
Well did finally get back in the shop and I understand from the dealer that in fact a bulletin just came out on the not engaging in drive or a delay of more then 2 seconds, in my case 5. They once again upgraded the software today for this issue, which was issued for 2004 XLR (which is nine) and a few others like CTS. I will know in the morning as I take off to go to work!:nopity
Ok, well they said just came out, however as I look at old postings, looks like it came out in 2005? oh well, if it works it all dosent matter?
UPDATE: Well no mater when it came out, it worked! Very happy XLR dude!
Well, I am not getting a warm a fuzzy with a fix based on the thread. It is strange, once a day in the morning, not cold just about 55 or 60! California!!! Oh well, I will bring back in durring the week. All other shifting is fine
I'm seeing the same thing on my 2004. I can back out of the garage just fine, then put it in drive and there's 2-5 seconds of what I'd call a seriously slipping clutch if it was a stick. Doesn't happen below 40-45 degrees or much over 55-60. One time I wound it up to about 3000 rpm before it engaged -- so abruptly that it chirped the tires.
Dealer's never heard of this, and of course it won't happen for them. But I see it on first startup any day the temperature's in the range.
Bulletin Number ???
Update
Do we have a specific Bulletin Number for this?
Anyone? Ken, is it one of the three you mentioned earlier in the thead?
Thanks.
Discussion Starter · #27 ·
Bulletins for your rear-end
Thanks.
Ben,
I'd have to refer the question about the three bulletins over to Bruce. I couldn't decipher them good enough to determine if they were applicable.
Also, under other thread, there was a new bulletin for a new fluid to take care of the "clunk" issue: http://www.xlrforum.com/showthread.php?p=29064#post29064
Ken
BoughtTheXLR
The only information I have is what is on the work order, however not sure if it will help. I don't have the bulletin number however it states, Reprogram PCM
Code 11Bc9
This did eliminate the problem on my 2004. Hope this helps
When shifting from 1-2 under fairly brisk acceleration, mine (05' XLR 40K miles)is making a "squeek" Sometimes it is barely perceptable over the sound of the engine. It is never very loud. Yesterday I had the top down, and it was much more noticeable. It doesn't do it all the time, but it doesn't matter if it is cold or warm. Anyone else have a similar malaise, or know what it might be?
i have same problem. On start up, goes into reverse ok, but when I put it in drive, it takes several seconds for the trans to engage. help please.
I had exactly the same problem with my 04, on cold startups on cool mornings. I'd back out of the garage, and after shifting into drive it was like I had a stick with a badly slipping clutch. Dealer did a transmission software update and that solved the problem. I'd tell you the info from the service ticket, but I handed them off when I traded for an 08.
21 - 31 of 31 Posts
