Has anyone experienced an issue of their tranny being "out of gear" and their engine free-revving? I can create the situation with a quick tip-in of throttle causing the transmission to downshift, then lifting off the gas, then back into the throttle. The feeling is one of the transmission downshifting and "hooking up", then when you lift off and back on it's as though it dropped out of the gear it was in and simply goes to "neutral" while it figures out what you want. During that time the engine free-revs if you continue to feed it fuel.
Doesn't seem to be that big an issue, just curious to see if anyone else has experienced this.
