Placing the top up, the driver's side sail panel/window didn't slip down into the fender slot where it's supposed to, but hung up on the gasket on the body. The alignment wasn't correct, sticking outward, so it pulled the gasket down into the slot with it. When the door window was raised, it aligned, INSIDE the sailpanel's front weatherstrip, so you couldn't open the door without lowering the window.The sail panel can be manually guided into its slot as the top is raised, so there may be some way to 'adjust' this correctly. I havn't had the time to take it to the dealer; frankly I'm concerned they don't know the car and its uniqueness well enough to effect a repair.
This MAY be similar to Mswaim's exploding panel, except mine didn't hang on the fender.
