1 - 2 of 2 Posts
Can anyone tell me what fuse or relay supplies power to the pump motor. My top stopped functioning and have to do it manually and need a starting point. Tu on advance. Merry Christmas and Happy New Year to All
The Instrument Panel Fuse Block is located on the passenger side of the vehicle, under the instrument panel and under the toe-board. Remove the carpet and toe-board covering to access the fuse block by pulling at the top of each corner of the panel. Then turn the fuse block door knob counterclockwise and pull the door to access the fuses. There are fuses and a circuit breaker that relate to various top functions.
1 - 2 of 2 Posts
