1 - 2 of 2 Posts
According to the maintance history, the radiator has never been replaced. I do occasionally see a pudle of green water under the car. The overflow tank is only about half full. I only have about 4 months left on the extended warrenty. Is there anything else i can check or should i just take it to the dealer. Thanks for your advise.
TAKE IT TO THE DEALER NOW!! You will either end up with a new "V" radiator OR a water pump. Both were known issues.
ALSO, I recommend you extend your warranty now for as long as you can.
Your antifreeze should be Dex Cool which is orange - unless someone put the older green type in after a change...
1 - 2 of 2 Posts
