Invisicord wiring to mirror
OK got up early this morning and looked at my wiring. The plug into the mirror is a 16pin connector with a pressure release at the top of it. Push down and pull the connector out. Looking at the connector from the back, my 2004 XLR has the following wires on the connector--there are 2 rows of 8 pins, I'll number them 1-8 from the left to right.
Top row
1. Black wire-no stripping
2. Blank--no wire in ths slot
3. Black with Orange stripe
4. Black with White stripe
5.-7. Blank no wires in these slots
8. Black with White stripe
Bottom row
1. Black with Purple stripe
2. Black with Orange stripe
3. Black with Yellow stripe
4. Black with Purple stripe
5. Black with Green stripe
6. Black with Blue stripe
7. Blank no wire in this slot
8. Black with Green stripe
I used the first slot in top row (Black wire) for my ground (Green wire on the invisicord) and the third wire on the bottom row (Black with Yellow stripe) for the hot wire. This setup works with the ignition. It will turn on when the car starts and go off when the car is off. I would think the wiring for all the years is the same,bu am not positive. I would check your wiring against my list above to verify your is like this. The invisicord is simple to install, as the connectors are flat and slide right into the slots in the back od the mirror connector. They also supply a little wire tie to secure the wire to the mirror wiring. Hope this helps everyone out looking for a quick install:seeya
Cubby558
