In regards to your paint chipping, I believe if you check the position of your top assembly when secured in the trunck you will find that the mounting screw or screws are to long for the fit clearance which will cause the paint. FIX: If this the problem take a file or grinder and level or reduce the excess length of the bolts.Goodluck I have a pilotcar #53 and it had that same problem.
