I hear the noise from both seats. When I turn them off it does stop. Noise is different from my 03 STS heated seats which make zero noise but then again donot offer cooling feature.
C below from a past poting awhile back>>
"the seats have a module which is basically a heat pump.
depending on the polarity to the module, it will either
create heat or absence of heat (coldness). a fan is used to
circulate the air through ducts. it takes a little time to
produce results. the module is efficient though, 100 watts,
- 7amps at 14 volts.."
