What's the bolt pattern on an XLR? 6 x ?" For those of you who've seen the OEM XLR wheel dismounted (or otherwise, 'know'), is it straight across from bead to bead, or is the OD of the wheel bewteen the beads tapered? I'd like to have a set widened for a hot rod application, but need some more info first.
Thanks for whatever info you can pass along!
