It's for diagnostics and this is where we used to put in the code for watching a DVD movie while driving, but they found out and we no longer have a code for 05 and above.
When I press and hold the hard button above the volume knob the screen displays a number key pad. It says Enter diag Pin. What is this about? I can't find it in the manual.
Disc upgrade
Thanks,
Is there any other use for the key pad? Another question. I bought my '06 XLR second handed. It sold new in March '07. It now has 700 miles on it. Will I qualify for the two free map upgrades?
Map DVD
Yes, you will. There is a number you can call that will connect you to the right people. Its on the back of the DVD case. They will look up your VIN. I would wait until fall for the new version to come out. I just got mine and its still not got a lot of streets around here. The guy said there is very little change from disk to disk. OK, OK Iknow your going to ask.................877-628-3472
I'm sure there is some other uses for the keypad but unless your a hacker, I wouldn't even think of trying anything on it. Just might wind up with the top going up and down by itsef.
Thanks,
