Just had to reset the seat positions yesterday.
Use the following steps to program each button:
1. Adjust the driver’s seat including the seatback recliner, lumbar and head restraint, both outside mirrors and the steering wheel to a comfortable position.
2. Press and hold button 1 until two beeps are heard, then release the button.
A second mirror, seating and steering wheel position can be programmed by repeating the above steps and pressing button 2 (for driver 2). Each time a memory button is pressed and released, a single beep will sound. Each time button 1 or 2 is pressed and released while the vehicle is in PARK (P), the memory positions will be recalled after a brief delay. If the vehicle is not in PARK (P), three beeps will be heard and the memory position will not be recalled. When the engine is started, the seat, mirrors, and steering wheel may automatically adjust to their
programmed positions. To stop recall movement of the memory feature at any time, press one of the power seat controls, power
mirror control buttons, memory buttons, or power steering column control.
Two personalized exit positions can be set by first recalling the driving position (by pressing 1 or 2), then positioning the steering wheel and seat in the desired exit positions and then pressing and holding the exit button until two beeps are heard. The exit button is located between buttons 1 and 2. With the vehicle in PARK (P), the exit position for the previously set driver can be recalled by pressing the exit button.
When you use the keyless access transmitter to unlock your vehicle, automatic seat and steering wheel movement to the exit position may occur. The numbers on the back of the transmitter, 1 and 2, corresponds to the numbers on the memory buttons. Further programming for automatic seat and mirror movement can be done using the Driver Information Center (DIC).
For programming information, see DIC Vehicle Personalization on page 3-73. 2
