small 1" square on the rear bumper take the large key that came with your car, When you trun the key it will uplatcch the trunk latch, You will need to hold the key in the turned position and push the truck lid up at the same time. Lifing the trunk lid can be very difficult because you do not have any power assist. You might want 2 people, one to hold the key turned and the other to lift the trunk lid open. It is not like you can turn the key and the truck lid will pop open, you need to hold the key turned while someone lifts the trunk lid. Once you are in the trunk the pull cord to open the driver door is located in a small compartment just abour 1" above the light on the left of trunk . There is a snall " 0 ring ", pull this toward the center of the trrunk, this will get you to a small compartment, 1" or 2" inches square, The pull cord for the driver side door is in this compartment. When you pull the cord you will NOT hear the door open,but it will be unlatched and you can open the door.
John
