1 - 3 of 3 Posts
guys this has been one of the worst car days i can remenber.first i lost or misplaced the master key to the wifes ls430 then i pulled the #1 battery jfuse out to try and get the check eng light on the xlr to go out no luck thinking like a obd1 system.the real problem with that is i dropped the fuse in the eng bay couldnt find it so was on my way to auto parts store and like a dummy i shut the hood now i cant get into the car guess #1 battery fuse must control door pads i also tryed using the key to open trunk no luck there either what should i do know
ONStar
Have you called OnStar to unlock your vehicle. Two problems here, if your car is inside, open your garage door to try and get more Radio waves from the satallite, it may not work because of the fuse you pulled.
Good luck
1 - 3 of 3 Posts
