leather
I own and run a Historic home and car restoration business. Mostly Rolls and Bentley. I have tried them all and have learned much about leather. There is a small company in NE PA called Color Plus they match leather for redying. There system comes several ways but you can buy there citrus leather cleaner which you dilute with water spray on clean and wipe off with a damp towel. Then the next day extremely lightly and for a few seconds sand the leather with a 220 paper that open up the pores of the leather and apply liberely. There leather rejuvenation oil used properly and often you can soften leather hard as a board!Then Park the car in the sun with the windows up! yes up! for a few hours the if the leather is new just use a a damp towel again to wipe off the excess and let dry.
NOTES! The reason most items do not work is your body oils have closed off the pores of the leather and everything you use just lays on top and does nothing.! Leather is suppose to be treated 2-3 times a yr! Thats why it drys out! Remember its just animal skin and that dries out very quickly when not tanned. YES ITS WORK BUT IT PAYS OFF! YOU DONT NEED TO DO THE TOTALLY OIL SOAKING ALL THE TIME UNLESS THE LEATHER IS OLD AND DRY. AFTER THE 1ST TIME YOU SHOULD BE ABLE TO JUST CLEAN ,WIPE DRY, OIL, WIPE, DONE! jiM f
