My ignition swicth has developed a bad habit. About 25-30% of the time, when I rock it down in order to hsut off the engine, it goes into Accessory Mode. It then does not cut off when you open the door (as it says it should in the Manual, even if it is in Accessory Mode). You must rock the swtich again to get it to completely shut down.
Anyone else having this trouble?
I have not been able to find a common pattern when this occurs.
