Passenger side are 2 lines coming from the trunk and up to and inside the top.
When lowering the top there is a small hole in one of the lines and squirts out hydraulic fluid.
Replace or try to repair by wrapping it with tape?
Perhaps have to take panel off of thee inside top to find out connection?
no repair to it . very high pressure and will need a new line. If yo ucheck where it goes into the pump there should be a number on it that you can get a replacement by at top hydraulics
Thanks Bion. How do you disconnect the line from the connection points?
Special tools? Sorry for all the questions, I gave the car to a special friend who has some impairment from brain surgery but loves to drive.
I understand and thanks. Incidentally, one of Top Hydraulics tutorials mentions a compression fitting for repair of leaking lines.
