Cadillac XLR Forum: XLR and XLR-V Forums banner
1 - 1 of 1 Posts
I had to change the thermostat on my 05. I tried a hose expander in the small hose on the housing but ended up picturing it and having to slit the end to get it off. This hose goes into a molded T fitting. I do not see a means of disconnecting the hose from the fitting. Is there a trick? Otherwise I may try to install a short piece on the housing and use a hose connector. ?What a PIA. ?I even had to remove the throttle body to access the housing. Thanks in advance for the help
1 - 1 of 1 Posts
