Yes! Right after washing the car. Look at the rotors and you will see they rust up pretty well after washing. This is normal as the metal that works best for brakes also rusts easily... not usually a problem since the heat generated by braking keeps them dry. The first couple of times after a drive-way-wash-and-back-to-the-garage results in a distict grinding noise until the rust coating is brushed off.Julie said:Yes, I have that grinding in the rear brakes when backing up and turning. My XLR is at the dealer right now for a paint scratch and the technician noticed it on his own as he was moving the car to their garage. They are looking in to it. I originally thought maybe the parking brake never fully released, but no messages ever came up to that effect. If they figure out what is causing the grinding, I will post it here.
Caly said:Yes! Right after washing the car. Look at the rotors and you will see they rust up pretty well after washing. This is normal as the metal that works best for brakes also rusts easily... not usually a problem since the heat generated by braking keeps them dry. The first couple of times after a drive-way-wash-and-back-to-the-garage results in a distict grinding noise until the rust coating is brushed off.
jackewells said:My 2005 doesn't seem to have this problem. Cup holders are reasonably cool and the seat temp is comfortable.
Cadillac knows this didn't fix itself and somebody at Cadillac knows what refinements were made from 04 to 05.
Stay on their case Bob and you will get it fixed. They don't want it back. :flag
jackewells said:Lucky you have that "V" on order...........It may take Allen most of the time from now to January fo complete your list............. :flag
jackewells said:Hi Bob....I agree they are good.......
So good that I sent Scott Allen a letter telling him so.
I first went to Allen on your recommendation...Maybe you can get some points for the referral. :flag
standby said:As some of you are aware, I got the so call fix for the heat coming from the console which didn't help. Going back east in 100 degree temps, the heat was so bad that I had to shift my body as close to the door as possible to get away from the heat, that I estimate was about 130 to 140. I wish I had had my heat gun from work with me so I could have verified it. I've told my dealer that I want the dash torn apart and a Y attachment put on one of the ducts feeding the vents and have it directed into the front of the console to cool this area. We couldn't put our water bottles in the cup holders or we would be drinking hot water within a half hours. The bottles of water had to be kept by the doors to keep them cooler.
I hope they will listen to me so I don't have to lemon law this vehicle, which I have documented for two times and this will be the third, I will have no choice but to Lenon law this vehicle.
What a shame, they actually crush a lemon so it is not sold to the public.
Quixotic said:After getting my car back Friday night from its first service, they told me ther was no fix for the center console heat. They also told me that they don't do the brake upgrade unless they squeal. Anyone know differently?
