Installed two new front shocks. All the mag fluid had leaked out and when I compressed them to remove they did not rebound at all. Ride quality was harsh to say the least. Put in the new shocks....easy and straightforward job. When I started the car I got the messages "service ride control" and "speed limited to 80mph". No messages were displayed before I did this work.
Scanned the codes and got
C 0579 Left front actuator circuit open Test not passed since ignition on
C 0584 Right front actuator circuit open Test not passed since ignition on
I can see all four actuators are "working" on the graphs in the scanner and respond to any movement of the car.
The shocks are not being commanded and stay at zero values.
If try and manually command the shocks on or off I get a malfunction from the computer.
Checked connector pins at top of each shock and even replaced one connector to no avail.
Any suggestions!?
Thanks!
Any suggestions!?
Thanks!
