For the third time (supposedly repaired in Nov and feb) I have lost all electronics in both doors, i.e. will not open except via manual lever, windows are stuck in all the way up mode, mirrors don't work and, of course, top will not go down. Will try again at yet another dealer to see if problem (supposedly a "relay" in the left door) can be fixed. :cry
Allen 1869,
Before you do that, take your negative ground off the battery for 25 seconds and then put it back on. It's like restarting your computer. Good Luck and hope that's not the year you where born.
Bobo
Hello, I know that was an old post but did you ever resolve the "door electronics" problem? I'm having the same. Thanks!
2005
Hello, all -
Help! The right door of my 2005 XLR will not open from the outside or inside. Indeed, the only way to get it open is to use
the manual lever. How can I fix this problem?? Maybe a fuse replacement? I'd rather not use the "take off the negative ground cable" method because, if I do so, I think I'll have to reset all the electronics. Your thoughts, please?
