I just replaced the grille on the front of my '05 with one that is chrome, but looks like the OEM grille. The directions were astonishingly long, but all you have to do is open the hood,
pop the four plastic nuts off (ok, I don't know what they are called).
Unscrew the four screws that hold the top of the OEM grille,
pull the grille forward with a long flat screwdriver, start unsnapping the bottom clips, (push pretty hard to get these loose and pull away from the front of the car. They will pop out pretty easily. You might want to use some painters tape to protect the bumper.
After the OEM grille is out, reverse the process. It will take about 1/2 hour to 45 mintes to do the whole job- and you don't have to take off the bumper cover and headlights, etc out like the directions tell you to do.
RickH:rant
RickH:rant
