I took delevery of my new XLR-V on Friday Morning. Before I was able to drive away we had to put a charger on the battery. Granted the doors ,hood,and trunk had all been opened and closed a number of times but no more than my XLR I had parked along side to transfer the contents to the new V. I was told that the battery had been fully charged duing the prepping of the car. Once home I hooked up the battery tender that had been always hooked to the XLR when not being driven. Once again after a few cycles of the top the battery again was not strong enough to properly shut the windows or operate the trunk. (I know the battery tender only outputs 2 amps) I am about to go drive the V for the day the tender has now been hooked up for over a day and the green light is on indicating a full charge, I would like to know if anyone else has had Battery Issues with their XLR-V ? And how you might have solved them. Has any one put in a larger battery?
Thank You in Advance for your input on this issue. Tim.
PS. The cadillac service dept tech installed a switch(we used a cadillac valet on /off switch) and located it in the rear of the center console, to control the exhaust baffles. It looks and works Great.
