1 - 2 of 2 Posts
I had a drivers side mirror that started going dark then light then dark , so to stop it you push the switch on left side of rear view mirror which turns it off ,but you got to do it each time you start car . you can fix it for good by turning the mirror down and to the outside then behind the mirror glass on right inside corner there is a small plug with two wires going in to it, use a small 45 degree needle nose pliers and pull up unplugging it from mirror, pull it out to side of mirror , take a small wire and push it in the plug making a jumper wire completing the circuit , tape it on and push back behind mirror, Fixed.
1 - 2 of 2 Posts
