2007 XLR
Where is the AC drain tube?
I'm not seeing water draining from the car after running the AC on hot days. I fear tube is stopped up. There is faint odor in interior.
I believe its just off center on the passengers side firewall tunnel. It near the exhaust so water usally gets evaparated. Check the drains on the passenger side under the fender behind the tire. They get stopped up wit trash and the odor can come in the car.
2007 XLR
Thanks @bion.
I already checked the drains on both sides and they were clear. Blew out the small drain hole in the left-side trunk compartment too as it had junk blocking it.
Just couldn't locate the AC drain.
Be careful blowing the side one out. I just run a plastic rod up them if you blow from the top at the roof if there isvan blockage you can blow the tubes off their nipple then water will drain in your floor. Very very light air pressure is ok but dont try to clear it with high pressure. Did you look at the tube in the firewall like i mentioned?
