XLR's advanced 32-valve, 4.6-liter Northstar V8 engine can change its valve timing, cam phasing, and throttle control to compensate for road conditions, driving styles, and even differences in fuel-intake. A new air induction system improves airflow, and noise and vibration are minimized.
SL500-Engine 4,966-cc SOHC 24-valve 90° V-8. High-pressure die-cast alloy cylinder block, alloy heads.Troy Roberts said:Pretty impressive for the first year model.
What are the Mercedes SL stats?
Damn tootin:jesterDarkHalo said:---------------------------------------------------------------------------------
Net power 493 hp @ 6,100 rpm
Net torque 516 lb-ft @ 2,750 - 4,000 rpm
0-60-4.5 seconds
:eek :eek :eek
Not too shabby
And for $150,000USD it can be yours.--------------------------------------------------------------------------------
0-60-4.5 seconds
Not too shabby
Originally posted by logansowner
Damn tootin:jester
Well, not quite that muchNomad said:And for $150,000USD it can be yours.![]()
Yeah, the AMG version is. :eeklogansowner said:Well, not quite that much![]()
Ill just take 3 Z06's instead....Nomad said:And for $150,000USD it can be yours.![]()
Notice the "from" in that price. If you want an engine, wheels, and seats to sit in it will drive the price up to around $150,000. :lollogansowner said:Technically, it's $114,000USD![]()
:iagreeSal Collaziano said:
I think Cadillac needs to get their v-series going right away. There was a lot of talk of a 400 horsepower supercharged Northstar for the XLR last year...
That's exactly what I read. They want the Vette to be the performance car. When the Vette HP goes up, the XLR's will too.Troy Roberts said:Maybe they will bump up the power after the C6 is out. They probably don't want it too close to the Corvette performance wise. It wouldn't look good for Corvettes if the standard XLR were faster than the standard Corvette.
Makes sense:cheersTroy Roberts said:Maybe they will bump up the power after the C6 is out. They probably don't want it too close to the Corvette performance wise. It wouldn't look good for Corvettes if the standard XLR were faster than the standard Corvette.
Yep, they don't want to bump their own performance flagship.Troy Roberts said:Maybe they will bump up the power after the C6 is out. They probably don't want it too close to the Corvette performance wise. It wouldn't look good for Corvettes if the standard XLR were faster than the standard Corvette.
