I have been looking at purchasing a 2006 model with 60K miles. Im nope really concerned about roof problems, oil leaks etc that I have been reading about. The top issue of them coming off has really got me concerned >. Any opinions or advise. Don’t know if I should look for some other car
I would ask myself a important question.
Do i have the money it takes to have it mechanically sound?
It could be a labor intensive fix
X$100.00 + per hour.
I have rebuilt motor, changed exhaust, put $35,000 on top of $34,000 purchase price.
Car is at shop now has a miss.
Not an everday car.
Maserati cost to fix Caddy?
You better think twice.
If you buy it put the best extended warranty you can afford.
Coolbrezze.
2006 supercharged XLR-V OWNER.
04 and 05 are the only years that seem to have the top delamination problem. Then only with darker colors in the sunny south or where the car gets hot a lot . May have been a couple later but the top is really not that bad an issue at all on 06 . The 06-09 is a better buy for a couple k more you get a better car and dont have to worry about the suspension module going out for 2500-3000 like on the 04/05. look at the headlights as 06 had an issue that the outer lens would delaminate from the housing. You should see a nice even grayish green area around the outside of th light. look that it is clear and even not cloudy . even press a little to make sure the lens is secure. it gets wind under it and its gone then a new 2000-2500 headlight is the only fix.
