Hey guys ive been looking a lot online to try and find anything that's remotely close to whats goin on with my car.. I have a 2004 xlr have 60k miles on it. bought it 9 months ago has been driving flawlessly. went to turn onto the interstate and died. tried restarting the car for 20 to 30 mins would turn over but wouldn't start. I went under the hood pressed the needle valve on the fuel rail to see if I had fuel and yes (not sure what p.s.i.). I called for help they arrived 15 minutes later we went to start and it fired rite up...drove it home sat for 1 hour drove to a neighboring town 30 miles away no problems came home. later that evening about 2 hours later drove to the bank about 2 miles away died again I let it set for 15 minutes acted like it wanted to start spitting and sputtering but wouldn't. after 2 hours nothing so I called a wrecker he loaded car drove 2 miles 30 minutes later unloaded the car pressed the start button and fired rite up ANY HELP PLEASE ?
Discussion Starter · #2 ·
update on shutoff
ok since no-one really updates after they get there cars fixed or diagnosed...thought I would update while I go along. I recently went out to test drive the car again to see if it would start after sitting for 2 weeks. pressed start all it would do is turn over. I checked the fuel rail again and now there is 0 pressure no gas at all coming out so im assuming its the fuel pump.
after much reading and investigation found out its the exact same setup as a corvette even the same parts. I tried to find a youtube vid of someone changing an xlr fuel pump and found nothing so next week we will be tackling this problem and ill post a youtube video link for others to try it also.. wish me luck ill update as I go.
ohhhh and also I do not want an acdelco pump im going for an American made aftermarket premium pump(non cheap china made) after talking to several dealers 3 of them told me there has never been a problem from a acdelco or recall from them on these pumps. when in fact I know there has been. im sure they have fixed the issues just don't trust them..
A Tech 2 is an indispensable scan tool to diagnose fuel delivery problems with the XLR. Unless you have one, you'll need to visit your local Cadillac dealer.
The twin-tank fuel delivery system is nearly identical to the C5 corvette.
The Fuel Pump Speed Control module (located behind the splash guard over the left/front wheel well) starts the fuel pump in the left side tank when the ignition is engaged. There's a secondary fuel pressure regulator in the left tank sender unit. The fuel pump contains a reverse flow check valve. This valve (along with the two pressure regulators) maintains fuel delivery pressure to prevent long cranking times.
Replacing the fuel pump is a big job as there's a lot of interference that has to be removed before the tank can be disconnected and removed to access the fuel pump. Unless you have a lift and access to all the tools, (after the proper diagnosis is made) I'd drive/flatbed the car to a dealership and then open your wallet wide.
CCC
doesnt throw any codes at all
it isn't throwing any codes at all I don't think a faulty fuel pump throws codes from what im reading. only the regulator does. I have rebuilt engines replaced heads ,water pumps, e.t.c. I hope with a lot of mechanical inclination that I can just take my time and it will be done correctly will start Thursday. and ill keep you guys updated and post a video of it so others in the future mite even try it. and its a better way to get to know your car inside and out.
Discussion Starter · #6 ·
the autopart store uses your techII also no codes or faults found after scans. I did find something weird , I left the acc on and it killed my battery, replaced battery car started rite up. the amp gauge you can see slightly move a little from 14 to 15 amps when I 1st put the battery in it was at 17 to 18 and its moving up and down ever so slightly ... altenator?
I had the same problem with my 04 . This problem went on for about a year . It got to the point that I was afraid to drive my car. I carried it to a dealer in Nashville Tn where they wanted 5800.00 to fix it . They were going to replace the entire fuel system. I told them NO THANKS. The tach 2 would not tell me what was wrong. With the help of a friend we hooked up a fuel pressure gauge with a long hose & taped it to the windsheld. He drove the car for 3 weeks & it never missed a lick.I picked it up & drove it a few days before it quit. I had 0 fuel pressure. We knew then that it was the fuel pump.We put it on the rack pulled the driver side exhaust, pulled the shifter linkage , drooped the fuel tank, & removed the old pump very carefully in peasies as not to split the tank. We re assembled Problem solved no problems since.
my xlr 2005 with 75K is doing something similar. It runs find for a while until it get warm then it acts like it is running out of gas, loses power and shuts off. I wait for a while and then it fires right back up. The Cadillac dealership says it is NOT showing any codes and therefore they do NOT know what is wrong with the car. Is there any other possibilities than a fuel pump? the car has excellent pressure when the car is running but when it cuts off the dealership says it loses pressure. They do not understand why it regains pressure after warming up? any and all suggestions would be greatly appreciated. I would also really appreciate a link to show how to remove a fuel pump. If it going to cost me $3k then I will have to find a way to do it myself! LOL
