keyless entry problem - Cadillac XLR Forum: XLR and XLR-V Forums
» Wheel & Tire Center
Go Back   Cadillac XLR Forum: XLR and XLR-V Forums > XLR Discussion > Cadillac XLR Technical Discussion > Key Fobs
Old 02-26-2013, 01:01 PM   #1
klausman
My 2006 XLR has a temperamental entry on the driver side. It will not immediately open until I move my finger tips around or restart the process. Eventually it does work. I changed the FOB battery without any success.
Any comments are welcome. Thanks
klausman is offline   Reply With Quote
Old 02-26-2013, 06:24 PM   #2
Kahuna
XLR Pit Crew
To start check the recent posts on the thread below 'locked out of my XLR!' Similar problem to yours discussed and resolved.
Kahuna is offline   Reply With Quote
Old 02-26-2013, 06:55 PM   #3
klausman
follow up
Kahuna, after reviewing the existing information on the threads, I didn't find any specific comments to help me with my issue. Thanks for the response.
Old 02-27-2013, 06:11 AM   #4
Strampe 09 XLR
keyless entry fix
If you remove the external door handle or pad(Two Screws and unplug) disassemble the handle(seven small screws on the back side), carefully clean all the contacts with electronics spray cleaner and pencil eraser, apply a small amount of die-electric grease to the contacts and reassemble. I had the same issue with mine; a friend suggested the same repair with my car and haven't had any further issues. This fix is very easy; it took me a matter of 10 mins to complete. Hope it works for you.
Strampe 09 XLR is offline   Reply With Quote
Old 02-27-2013, 05:19 PM   #5
wb6bbz
XLR Pit Crew
I would suggest that you read and perform the section on 'Programming the FOB' in the Owner's Manual.
It sounds like you just need to re-fresh your FOB's program.
Do you have the same problem with both FOBs?( Asumming you have more than 1 of course.)
Good Luck,
__________________
Jack
06StarBlackMet165/250Limited Edition
TintedWindows
CorsaExh
VolantCAIw/2e-RamElectric-Superchargers
9thFuelInj
385+CalcFlywheelHP
RearSwayBar
TrailerHitch
HBWindscreen&Spoiler
CurbAlert
wb6bbz is offline   Reply With Quote
Old 02-27-2013, 08:39 PM   #6
ccclarke
Administrator
ccclarke's Avatar
I recently had a very similar problem with my drivers side door touch pad. It would intermittently work and I had to press in different spots to get it to finally command the door to unlatch. --Frustrating and embarassing, especially when you're in a hurry after filling up!
I purchased a new switch for less than $20 online and installed in less time than it takes to write this up. Voila! It works perfect every time now. Of course, it makes sense--the drivers side switch gets a lot more use than the passenger side, so it's bound to have a higher failure rate.
CC
Old 02-28-2013, 09:11 AM   #7
wb6bbz
XLR Pit Crew
Ok, I'm confused. Were you having problems with the 'Touch Pad' in the door, or your FOB?
Please clarify!
__________________
Jack
TintedWindows
CorsaExh
9thFuelInj
385+CalcFlywheelHP
RearSwayBar
TrailerHitch
CurbAlert
Old 03-01-2013, 10:06 AM   #8
klausman
keyless access
jb, the problem lies with the door touch pads.
Old 03-01-2013, 10:10 AM   #9
klausman
keyless access
cc and strampe,
I think I will try Strampe's fix first and if it doesn't correct things, I will buy a switch like cc.
Thank you all for your kind response, I appreciate it.
Old 03-02-2013, 07:00 AM   #10
dws
XLR Pit Crew
Thanks for the info. sounds like the best way. Here a web site everyone may enjoy go to
mitocorp.com for a new oem nav system
Must see BLACK DIAMOND WHEEL.COM
dws is offline   Reply With Quote
Old 03-11-2013, 01:34 PM   #11
klausman
Just a follow-up to let everyone know what results I had. I did exactly what Strampe suggested and could not believe how simple it was. After disassembling the pad and spraying it with electronic cleaner and wiping the contacts (gently) I was really pleased with the improvements. The door pad works like new. So thanks again for the information, I sincerely appreciate it.
Old 03-13-2013, 08:34 PM   #12
Strampe 09 XLR
Glad I could help; Take care.
Old 03-15-2013, 04:11 PM   #13
ddtier
XLR Pit Crew
+1
+1. I just cleaned ours today and the doors pop instantly. The drivers door was getting real bad but the passenger door improved too. Had to use commutator burnishing tool to cut through the crud on the copper side. Followed up with dielectric grease. I think I may go ahead and order new ones as they are dirt cheap and still available. Planning on keeping our XLR for a long time. Gonna clean the trunk release next. Its a little harder to get to.
Thanks to all for sharing of information!
Dave
ddtier is offline   Reply With Quote
