Temp too cool - Cadillac XLR Forum: XLR and XLR-V Forums
» Wheel & Tire Center
Go Back   Cadillac XLR Forum: XLR and XLR-V Forums > XLR Discussion > Cadillac XLR Technical Discussion > Radiator and Cooling
Old 11-30-2012, 05:08 PM   #1
march
Temp too cool
I have an '06 base with 63000 kilometeres. When it is cold out it is slow to warm up and my temperature gauge doesn't go past 40C or 100F, the oil pressure is high, and sometimes the guage will suddenly drop down to zero, the check engine light comes on, and the radiator fans start running at all times. I verified the temp at the thermostat is only 40C or 100F with a laser point guage. I am told the thermostat is almost never problem and others who have had this problem don't solve it with a new thermostat. The check engine code is p0128 low temp. Hogwash had this problem exactly but he has not said how he solved it. Please help or if any of you know Hogwash ask him if he solved this.
march is offline   Reply With Quote
Old 12-01-2012, 11:13 AM   #2
xlrlist01
XLR Pit Crew
Quote:
If the engine temperature as measured with a touch-less thermometer is also 100 degrees, then 99% you have a faulty thermostat, assuming sufficient time to warm up. It sounds like you have more than one defect though. Modern thermostats are designed to fail open (they used to fail closed) and in my experience they always fail in the end, just a matter of time. Still, 6/7 years is a bit early.
Change the thermostat and see what happens.
HTHs
xlrlist01 is offline   Reply With Quote
Old 12-08-2012, 06:20 AM   #3
march
Changed the thermostat today and problems are solved. The thermostat was damaged - a rubber seal in the thermostat tore and held it open. Now it tells me to Service Active Handling - next problem.
