Temp Sensor?? - Cadillac XLR Forum: XLR and XLR-V Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Cadillac XLR Forum: XLR and XLR-V Forums > XLR Discussion > Cadillac XLR Technical Discussion > Radiator and Cooling
XlrForum.com is the premier Cadillac XLR Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
Old 02-13-2012, 11:18 AM   #1
Hogwash
Member
Temp Sensor??
Hi all,
I have an '05 with 70k miles. Sometimes when it is cold out (40F or less usually) I've noticed my temperature gauge will suddenly drop down to zero, the check engine light comes on, and the radiator fans start running at all times. If i turn off the car and turn it back on it again, the temperature gauge comes back up as normally, and after 100 miles or so the check engine light turns off. This phenomenon happens quite often. Any ideas of what it could be? I'm guessing a bad sensor of some type... Thanks!
Hogwash is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-13-2012, 03:51 PM   #2
XLR I FL
Administrator
XLR I FL's Avatar
Since you are headed to the dealer for the top I would have them check the codes for this issue too.
It doesn't take long and should be under $100 to find out what is really going on with all of the issues your XLR has and what it will cost you to fix.
XLR I FL is offline   Reply With Quote
Old 11-15-2012, 03:02 PM   #3
march
Member
Quote:
Originally Posted by Hogwash View Post
Hi all,
Did you find out what the temp. problem was? I have the same issue and the code is low coolant temp.
march is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
