Gas Door Latch Won't Stay Closed - Cadillac XLR Forum: XLR and XLR-V Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Cadillac XLR Forum: XLR and XLR-V Forums > XLR Discussion > Cadillac XLR General Discussion
XlrForum.com is the premier Cadillac XLR Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
Old 10-19-2012, 08:42 AM   #1
mysmith4
Member
I filled up my 2005 XLR with gas last night and the check engine light came on this AM which prompted me to open the gas door. Now the gas door won't close. I think the latch is broken. A quick fix was to put clear masking tape over it but I refuse to ride in an XLR with tape on it! Is this an easy fix or will I need to have it serviced by Cadillac? I haven't had the car for a full month yet and this will be the third visit to Cadillac dealership - air bag light; svc tire monitor message; window stripping/bracket repair on right side window.
mysmith4 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-20-2012, 04:45 AM   #2
xlrlist01
XLR Pit Crew
Quote:
Is it broken or has the latch stuck in the open position? If you open the trunk there is a manual release cord, try manipulating that. Maybe a shot of lubricant on the latch will do the trick? The latch is a shaft inside a tube and maybe it needs a tiny bit of light-weight lube, hopefully.
Don't use a silicon based lube near gas, silicone is death to O2 sensors.
xlrlist01 is offline   Reply With Quote
Old 11-05-2012, 03:38 PM   #3
Rgmiller
Member
Gas Door
Mine did this and would eventually comes back out (plunger that latches the door) after driving.
In any case it is a solenoid tat needs replacing. Mine was replace 6 months ago under GMPP warranty.
It is a nuisance, but got worse over time.
Rgmiller is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
